So here it is... Mainly using the mesa studio preamp for all the basic tones then pedals for different dirty tones and the sx700 for for delays etc... It then goes into the cabtone. I can also play acoustics by bypassing everything except the tc electronic reverb.
new rig day.....my direct in rig...
Re: new rig day.....my direct in rig...
Everything runs thru the gcx. I go from guitar into the weeping demon wah, then into the gsx.
Loop 1 is a joyo sweet baby drive pedal
Loop 2 is a joyo vintage distortion which is a screamer cloan,
Loop 3 is a dirty little secret catlinbread Marshall type drive
Loop 4 Is the mesa studio preamp.
Loop 5 is the clean/ lead switching of the preamp.
Loop 6 is the boss sx700 which is the mulit effects unit
Loop 7 is the boss ge7 eq
Loop 8 is the tc electronics hall of same reverb
Then it goes into the cabtone cab Sim.
I can set up patches or I can use it adding any pedal in the loop. If i have the fx unit in the loop I can use the bottom midi pedal ( midi moose) as a stomp box set up to just change the patches on the boss. So if I wanted to add more delay I can just program a patch to one of the switches or even set up one for octives, phasers, flangers, delays, reverbs, tremolo, ect.
I can also plug up the acoustics and bypass everything but the reverb. Hope this makes sense.
