Voltage Doubler Cable – 2.5mm Reverse Polarity – 18″
For pedals with higher voltage requirements, the reverse polarity 2.5mm Voltage Doubler Cable (PPEH24) will combine two 9V or 12V Pedal Power outputs to create a single 18V or 24V output. This cable features two 2.1mm barrel plugs to a single 2.5mm barrel plug for use with center-positive polarity pedals. Ideal for Electro-Harmonix Deluxe Memory Man, Stereo Memory Man, Electric Mistress and others that require 24V. Flanger Hoax (18V) also requires this cable.
$7.99
Features
  • Combines voltage of two Pedal Power isolated outs
  • Reverse polarity for center-positive effects
  • Custom-designed by Voodoo Lab for optimal performance with Pedal Power
  • Nickel-plated barrel plugs secure solid connections between power supply and effects
  • 22-gauge copper wire for superior current handling
  • Coaxial design allows greater cable flexibility
  • Durable PVC insulation ensures long cable life
  • Made in China
  • Part# PPEH24
Specifications
  • Power Supply Connector
  • Two (2) 2.1mm straight barrels (Black)
  • Pedal Connector
  • One (1) 2.5mm straight barrel plug (Red)
  • Polarity
  • Reverse (center-positive)
  • Length Options
  • 18” (46cm)
