2.1mm Right-Angle Barrel Connector on a 36″ Cable
A 2.1mm right angle barrel connector on a 36 inch/92 cm cable terminating with a bare end. DIY parts are recommended for users who have experience soldering cables together. Otherwise, fully assembled custom cables can be ordered directly from Voodoo Lab at a reasonable cost.
$3.29
Features
  • 36" bare cable with 2.1mm right-angle barrel plug on one end
  • Custom-designed by Voodoo Lab for optimal performance with Pedal Power
  • Nickel-plated barrel plugs secure solid connections between power supply and effects
  • 22-gauge copper wire for superior current handling
  • Coaxial design allows greater cable flexibility
  • Durable PVC insulation ensures long cable life
  • Made in China
  • Part# PP36-R
Specifications
  • Connector Style
  • Right-angle barrel
  • Connector Inner Diameter
  • 2.1mm
  • Connector Outer Diameter
  • 5.5mm
  • Cable Length
  • 36 in (92 cm)
