2.5mm Straight Barrel Connector
A 2.5 mm x 5.5mm straight barrel connector that can be soldered to the 36 in/ 92cm cables with a bare end. DIY parts are recommended for users who have experience soldering cables together. Otherwise, fully assembled custom cables can be ordered directly from Voodoo Lab at a reasonable cost.
$1.99
Features
- 2.5mm straight barrel connector
- Premium-quality connector for optimal performance with Pedal Power
- Nickel-plated barrel plugs secure solid connections between power supply and effects
- Part# CBAR25
Specifications
- Connector Style
- Straight barrel
- Connector Inner Diameter
- 2.5mm
- Connector Outer Diameter
- 5.5mm
- Connector Length
- 1.2 in (31 mm)
