Tremolo
The Voodoo Lab Tremolo re-creates the buttery, seductive tone of a vintage tube amp tremolo. This is accomplished by using the same lamp and photocell assembly found in many popular vintage amps.
This pedal also features a slope control which lets you adjust the feel from a traditional soothing tremolo to a hard “machine-gun” stutter. Speed and intensity controls provide a wide range to include very slow and deep sounds. A volume control lets you cut or boost the output level. Now you can add warm, mind-bending trem vibes to any amp with the most versatile tremolo available.
“Nicely voiced, with very slow and very fast speeds…” -Guitar Player
$149.99
Tremolo Features
  • Authentic lamp and photocell tremolo circuit
  • Slope control for waveform tweaking
  • Ultra wide range of Speed and Intensity settings
  • True bypass switching via high-reliability gold-contact relay
  • Runs on a 9V battery
Tremolo Specifications
0.85 lbs. (386g)
9V DC, 30mA
VS
CONTROLS
  • INTENSITY – Controls the amplitude of the tremolo waveform
  • SLOPE – Varies the shape of the tremolo waveform
  • SPEED – Controls the rate of the tremolo
  • VOLUME – Controls the output level of the effect
CLASSIC SETTINGS
  • Shimmer – Set the intensity around 3:00 and the speed nearly all the way up.
  • Surf – Set the intensity around 2:00 and the speed around 3:00.
  • Leslie – Turn the intensity all the way up and set the speed to the desired tempo. Between 12:00 and 2:00 is generally preferred.
  • Stutter – Turn the slope all the way up. Set the intensity all the way up and the speed as desired
Tremolo
